Use the following procedure to enable DHCP Snooping globally. If DHCP Snooping is globally disabled, the switch forwards DHCP reply packets (received on trusted or untrusted ports) to all ports.
- Select DHCP Snooping.
- Select the DHCP Snooping Globals tab.
- Select Enabled.
- Select Apply.
DHCP Snooping Globals Field Descriptions
Use data in the following table to use the DHCP Snooping Globals tab.
| Name | Description |
| Enabled | Enables DHCP Snooping globally. By default, DHCP Snooping is disabled. |
